ANSYS Workbench on "Uncertified" Linux Distros |
November 5, 2010, 17:17 |
CFX Pre and Solver Broken
#81 |
Scott Johnson
Rep Power: 15 |
First off, I would like to thank you all for the helpful information you have posted here. I now have workbench, design modeler, and mesh all working thanks to the information provided here.
I recently got a new computer, and have installed both Ubuntu 10.04.1 and Ubuntu 10.10, both 64 bit, on this machine. My previous computer was running 64 bit Ubuntu 10.04, and I had CFX Pre, Solver & Post all working great (run with ansys_inc/v121/CFX/bin/cfx5), but DM and Mesh both did not work (I hadn't followed all the steps outlined here). Workbench would come up, but I couldn't do much with it. Now, after installing on my new computer, when I try to run CFX Pre (either from workbench or directly from ansys_inc/v121/CFX/bin/cfx5), I get the following error: Code:
-- ERROR -- CCL validation failed with message: Warning: Can't check parameter Message (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Message): Can't find rule. Warning: Can't check parameter Message Type (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Message Type): Can't find rule. Warning: Can't check parameter Severity (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Severity): Can't find rule. Warning: Can't check parameter Suppressed (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Suppressed): Can't find rule. I also am not able to run CFX solver, and get the same error as above on the command line, and this additional error if I try to run the solver from within workbench: Edit: I forgot to mention that CFX post runs just fine. The issue is only with Pre and Solver. Code:
Ans.Core.Commands.UserReadableFailure: Unexpected Solver Input File request from empty Setup component. at Ans.CFX.CFXCore.Data.CFXSetupSource.GetSolverInputFile (Ans.Core.Commands.CommandContext context) [0x00000] at Ans.CFX.CFXCore.Data.CFXSetupProvider.DoRetrieveData (Ans.Core.Commands.CommandContext context, Guid connectionKey) [0x00000] at Ans.CFX.Foundation.Data.TransferDataObject.RetrieveData (Ans.Core.Commands.CommandContext context, Guid connectionKey) [0x00000] at Ans.CFX.Foundation.Data.RetrieveDataCommand.Execute (Ans.Core.Commands.CommandContext context) [0x00000] at Ans.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ans.Core.Commands.CommandContext subContext, IExecutionEngineCallback tracer) [0x00000] --- Ans.Core.Commands.CommandFailedException: Unexpected Solver Input File request from empty Setup component. Command: CFX.RetrieveData(Entity="/Setup/CFXSetup:Setup Provider", ConnectionKey="6e264da9-49a2-4c1b-b86d-f1ea8deeeb82") at Ans.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x00000] at Ans.Core.Commands.CommandAsyncResult.Wait (Int32 milliSecondsTimeout, Boolean exitContext) [0x00000] at Ans.Core.Commands.CommandAsyncResult.Wait () [0x00000] at Ans.Core.Commands.CommandContext.InvokeCommandAndWait (IProgressMonitor progressMonitor, Ans.Core.Commands.Core.CommandInfo commandInfo, Ans.Core.Commands.ArgDictionary args) [0x00000] at Ans.Core.Commands.CommandContext.InvokeMethodAndWait (IProgressMonitor progressMonitor, IObjectReference objRef, System.String methodName, Ans.Core.Commands.ArgDictionary args) [0x00000] at Ans.Core.Commands.CommandContext.InvokeMethodAndWait (IObjectReference objRef, System.String methodName, Ans.Core.Commands.ArgDictionary args) [0x00000] at Ans.CFX.Foundation.DataTransfer.DataLink.RetrieveData (Ans.Core.Commands.CommandContext context) [0x00000] at Ans.CFX.CFXCore.Data.CFXSolutionSource.GetUpstreamSetup (Ans.Core.Commands.CommandContext context) [0x00000] at Ans.CFX.CFXCore.Data.CFXSolutionSource.DefineRun (Ans.Core.Commands.CommandContext context) [0x00000] at Ans.CFX.CFXCore.Commands.EditRunDefinitionCommand.Execute (Ans.Core.Commands.CommandContext context) [0x00000] at Ans.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ans.Core.Commands.CommandContext subContext, IExecutionEngineCallback tracer) [0x00000] --- Ans.Core.Commands.CommandFailedException: Unexpected Solver Input File request from empty Setup component. Command: CFX.EditRunDefinition(Container="Solution") at Ans.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x00000] at Ans.Core.Commands.CommandAsyncResult.Wait (Int32 milliSecondsTimeout, Boolean exitContext) [0x00000] at Ans.Core.Commands.CommandAsyncResult.Wait () [0x00000] at Ans.CFX.CFXCore.Commands.EditRunDefinitionCommand.InvokeAndWait (ICommandContext context, Ans.Core.DataModel.ProjectSystem.DataContainerReference Container) [0x00000] at Ans.CFX.CFXCore.Commands.EditRunDefinitionGui.Invoke (Ans.UI.GuiOperationContext context) [0x00000] at Ans.UI.GuiOperationContext.Invoke (Ans.UI.GuiOperationMetaData operationData) [0x00000] at Ans.UI.UIManager+<InvokeOperation>c__AnonStorey1A.<>m__16 () [0x00000] at Ans.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ans.UI.Views.OperationDelegate callback, Boolean allowOSMessages) [0x00000] This is what is shown in the solver window: +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ SIMULATION CONTROL: END ccl2flow: * command language error * Message: getChildList: unable to find the requested path Context: returned by cclApi call +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | /Software/ansys_inc/v121/CFX/bin/linux-amd64/ccl2flow.exe exited | | with return code 3. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | An error was encountered in problem setup. See the output file | | | | /work/CFD/CFX_001.out | | | | for more details. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. In case it is helpful to anyone else, below are the steps I took to get workbench, DM and Mesh working: Code:
1) edit /etc/hosts so that my hostname only appears on one line. For example, I changed something like: 10.0.0.XX MYHOSTNAME # Added by NetworkManager 127.0.0.1 MYHOSTNAME to 10.0.0.XX MYHOSTNAME # Added by NetworkManager #127.0.0.1 MYHOSTNAME # Commented Out 2) sudo aptitude install mesa-utils gamin sudo aptitude remove rpm alien sudo aptitude install libmotif3 3) Make an executable file called 'rpm' and copied to /usr/bin/ which contained the following: #!/bin/bash echo glibc-2.12.1 4) Make an executable file called 'uname' containing the following: #!/bin/bash if [ "$1" = "-i" ]; then echo ` uname2 -m | sed -e '/i686/s//i386/' ` else uname2 $@ fi then: sudo mv /bin/uname /bin/uname2 sudo cp uname /bin/ 5) Install ANSYS by calling the INSTALL script that unpacks with the installation. 6) Register the libraries: find /work/Software/ansys_inc/v121/aisol/dll/linx64/ -iname "*.so*" | sudo xargs /work/Software/ansys_inc/v121/aisol/workbench -cmd /work/Software/ansys_inc/v121/aisol/mw/bin-amd64_linux_optimized/regsvr32 -c -nodisplay 7) Added the following to my .bashrc file: export AWP_ROOT121=/work/Software/ansys_inc/v121 export ANSYS121_DIR=${AWP_ROOT121}/aisol export PATH=${PATH}:${ANSYS121_DIR} RUNWB2_DIR=${AWP_ROOT121}/Framework/bin/Linux64 export PATH=${PATH}:${RUNWB2_DIR} export PATH=${PATH}:${AWP_ROOT121}/CFX/bin 8) Finally I created the script to run workbench called wb2: #!/bin/bash LD_LIBRARY_PATH="/Software/ansys_inc/v121/aisol/mw/lib-amd64_linux_optimized:/Software/ansys_inc/v121/aisol/lib/linx64/:/usr/lib/nvidia-current" export LD_LIBRARY_PATH export LANG=en_US.UTF8 export MALLOC_CHECK_=0 /Software/ansys_inc/v121/Framework/bin/Linux64/runwb2 export MALLOC_CHECK_=2 Last edited by Scott Johnson; November 5, 2010 at 18:10. |
December 6, 2010, 04:22 |
Ansys 13 on Ubuntu 10.04
#82 |
makkemal
Rep Power: 15 |
Have anyone figured out how to run Ansys 13 on ubuntu 10.04
I have 12.1 running well on 10.04 with the instruction posted on this Forum. I have Installed 13 but It does not work. I can get the framework running by running as sudo but nether DM or mechanical want to start Thanks M |
December 7, 2010, 11:56 |
#83 |
Scott Johnson
Rep Power: 15 |
I have tried to install ANSYS V13 on my Ubuntu 10.10 64 bit machine. Things have gotten worse, not better than V12.1 for me. Basically, everything is broken -- I can run workbench, but every component (DM, CFX, etc) won't work.
December 10, 2010, 12:12 |
#84 | |
Yves Delannoy
Rep Power: 16 |
Here attached (procedure.txt) is my installation procedure - notice the trick about graphic libraries ( also mentionned in http://doc.ubuntu-fr.org/ansys_workbench ) and the need to control your /etc/hosts, where Network Manager adds two lines containing your hostname (one for ipv4, one for ipv6) which causes problems for ansys... |
December 10, 2010, 23:55 |
#85 |
Scott Johnson
Rep Power: 15 |
Yankee,
Thank you for the reply. Unfortunately, I can't read your attached procedure. I get an error that says the source file could not be read. Any chance you could try to post it again? Thanks again, Scott Last edited by Scott Johnson; December 13, 2010 at 19:04. Reason: typo |
December 12, 2010, 16:20 |
#86 | |
Yves Delannoy
Rep Power: 16 |
# Installation procedure for Ansys13.0 on ubuntu10.10 - 64bits # 1. enter root session for steps 1-7 (assuming you're allowed to do that, it will ask YOUR passwd and not the one of root) sudo -s # 2. add "rpm" and "uname" custom commands to make the installer happy (supposing /usr/local/bin is in the PATH) cat > /usr/local/bin/uname <<'eof' #!/bin/bash if [ "$1" = "-i" ]; then echo `/bin/uname -m | sed -e 's/i686/i386/' ` else /bin/uname $1 fi eof chmod +x /usr/local/bin/uname cat > /usr/local/bin/rpm <<'eof' #!/bin/bash echo glibc-2.12-1 eof chmod +x /usr/local/bin/uname # 3. be sure that your hostname appears in only 1 uncommented line of /etc/host grep `hostname` /etc/hosts # if it appears more than once edit it manually and make it immutable to avoid changes by netmork manager : chattr +i /etc/hosts # 4. download ANSYS130_LINX64_DVD1.iso and ANSYS130_LINX64_DVD2.iso from ansys customer portal into /tmp (not described) # 5. install ansys (choosing its installation directory, and the products for which you have licenses) # at the middle of install indicate "/mnt/iso2" as location for the second DVD # at the end of install you should provide the name of your license server and verify its ports # don't be afraid of the 12 messages "[: 335: xxx.so: unexpected operator" in /ansys_inc/install.err cd /tmp mkdir /mnt/iso1 /mnt/iso2 mount -o loop -t iso9660 ANSYS130_LINX64_DVD1.iso /mnt/iso1 mount -o loop -t iso9660 ANSYS130_LINX64_DVD1.iso /mnt/iso2 cd /mnt/iso1 ./INSTALL cd /tmp umount /mnt/iso1 /mnt/iso2 rmdir /mnt/iso1 /mnt/iso2 # 6. define environement variables for all users (assuming they use bash) - adapted from "post-install procedures" in ai_unix_2828.pdf cat > /etc/profile.d/ansys_config.sh << 'eof' SYSVAR=`uname -m` # to choose between 32bit or 64bit pathes if [ ${AWP_ROOT:-undefined} = undefined ]; then export AWP_ROOT=/ansys_inc/v130 ; fi if [ ${ANSYS_DIR:-undefined} = undefined ]; then export ANSYS_DIR=${AWP_ROOT}/aisol ; fi if [ ${SYSVAR} = 'x86_64' ]; then if [ ${ICEM_ACN:-undefined} = undefined ]; then export ICEM_ACN=${AWP_ROOT}/icemcfd/linux64_amd ; fi RUNWB2_DIR=${AWP_ROOT}/Framework/bin/Linux64 ; else if [ ${ICEM_ACN:-undefined} = undefined ]; then export ICEM_ACN=${AWP_ROOT}/icemcfd/linux ; fi RUNWB2_DIR=${AWP_ROOT}/Framework/bin/Linux32 ; fi if [ ${ANSYSLIC_DIR:-undefined} = undefined ]; then export ANSYSLIC_DIR=/ansys_inc/shared_files/licensing ; fi if [ -d ${ANSYS_DIR} ]; then export PATH=${PATH}:${ANSYS_DIR} ; fi if [ -d ${RUNWB2_DIR} ]; then export PATH=${PATH}:${RUNWB2_DIR} ; fi # path to runwb2 if [ -d ${AWP_ROOT}/fluent/bin ]; then export PATH=${PATH}:${AWP_ROOT}/fluent/bin ; fi # path to fluent if [ -d ${AWP_ROOT}/CFX/bin ]; then export PATH=${PATH}:${AWP_ROOT}/CFX/bin ; fi # path to cfx5 if [ -d ${AWP_ROOT}/TurboGrid/bin ]; then export PATH=${PATH}:${AWP_ROOT}/TurboGrid/bin ; fi # path to cfxtg if [ -d ${ICEM_ACN}/bin ]; then export PATH=${PATH}:${ICEM_ACN}/bin ; fi # path to icemcfd if [ -d ${ANSYSLIC_DIR}/lic_admin ]; then export PATH=${PATH}:${ANSYSLIC_DIR}/lic_admin ; fi # path to anslic_admin eof # 7. create a command "wb2" to add access to the mesa libes of your graphic driver (here, nvidia) and running workbench (supposing /usr/local/bin is in the PATH) cat > /usr/local/bin/wb2 <<'eof' #!/bin/bash if [ -d /usr/lib/nvidia-current ]; then export LD_LIBRARY_PATH=`echo /usr/lib/nvidia-current:$LD_LIBRARY_PATH | sed -e 's/:$//'` ; fi runwb2 $@ eof chmod +x /usr/local/bin/wb2 # 8. quit root session entered in 1. exit # 9. For each user, verify the license (clic on "View Status/Diagnostic Options" then "display the license status") # and eventually choose your prefs ("Set License Preferences for user xxx" then v12.1 then, ie "Use Academic Licenses" if you have some...) anslic_admin # 10. logout, login (to activate /etc/profile.d/ansys_config.sh), run ansys and enjoy! wb2 Last edited by Yankee; December 14, 2010 at 16:02. |
December 13, 2010, 19:03 |
#87 |
Scott Johnson
Rep Power: 15 |
Yankee,
Thanks for the help! Your instructions on how to prevent /etc/hosts from getting changed was very helpful. I didn't realize it, but my /etc/hosts had changed, and I did have multiple lines with my hostname again. I am hopeful that was part of my problem. I realized that I had erased my ANSYS 13 install, and so I am having to download it again before I can test out your suggestions. In the mean time, I have a couple of questions/comments: 1. In step 3, when I do ldd --version I get "ldd (Ubuntu EGLIBC 2.12.1-0ubuntu9) 2.12.1", so I changed your 'echo glibc-1.12-1' to 'echo glibc-1.12.1'. was this a typo, or did this work for you the way you had it? 2. I think you forgot to add a few lines to your wb2 script (like calling runwb2). Can you tell me if you export any other environment variables in your wb2 script (like export LANG=en_US.UTF8 or export MALLOC_CHECK_=0, etc.)? Also, do you use the -oglmesa flag with runwb2? Thanks again, Scott |
December 14, 2010, 11:04 |
#88 |
Scott Johnson
Rep Power: 15 |
Alas, I am still plagued with CCL errors. When I try to open CFX PRE, I get the following error:
p, li { white-space: pre-wrap; } CFX-Pre Application Error ERROR CCL validation failed with message: Warning: Can't check parameter Message Type (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Message Type): Can't find rule. Warning: Can't check parameter Severity (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Severity): Can't find rule. Warning: Can't check parameter Message (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Message): Can't find rule. Warning: Can't check parameter Suppressed (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Suppressed): Can't find rule. Code:
p, li { white-space: pre-wrap; } Ansys.Core.Commands.UserReadableFailureException: The CFX Solver for system Copy of Fluid Flow (CFX) did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution component. at Ansys.CFX.CFXCore.Data.CFXSolutionSource.HandleRunFailure (IFullContext context, Ansys.CFX.CFXCore.Data.CFXSolverRun run) [0x00000] at Ansys.CFX.CFXCore.Data.CFXSolutionSource.OnTaskReconnect (IFullContext context, Ansys.Addins.Infrastructure.Rsm.Data.SolverTask task, CommandCancellationStatus interruptStatus) [0x00000] at Ansys.Addins.Infrastructure.Rsm.Data.SolverTask.Reconnect (IFullContext context) [0x00000] --- Ansys.Core.Commands.CommandFailedException: The CFX Solver for system Copy of Fluid Flow (CFX) did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution component. CommandName: CFX.UpdateSolution(Container="Solution 1") at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x00000] at Ansys.Core.Commands.CommandAsyncResult.Wait (Int32 milliSecondsTimeout, Boolean exitContext) [0x00000] at Ansys.Core.Commands.CommandAsyncResult.Wait () [0x00000] at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (IFullContext context, IProgressMonitor progressMonitor, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.Collections.Generic.List`1 downstream, System.Collections.Generic.List`1 allRemaining) [0x00000] at Ansys.ProjectSchematic.Update.UpdateImpl.updateComponent (IFullContext context, Ansys.ProjectSchematic.Update.UpdateTask task) [0x00000] at Ansys.ProjectSchematic.Update.UpdateImpl+<updateComponentAndDependencies>c__AnonStorey6A.<>m__56 () [0x00000] at Ansys.ProjectSchematic.Update.UpdateImpl.executeWithSelectedErrorBehaviour (Ansys.ProjectSchematic.Update.Op op, Ansys.ProjectSchematic.Update.UpdateTask forTask) [0x00000] --- System.InvalidOperationException: Update of the Solution component in Copy of Fluid Flow (CFX) failed: The CFX Solver for system Copy of Fluid Flow (CFX) did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution component. at Ansys.ProjectSchematic.Update.UpdateImpl.doOutstandingTasks (IEnumerable`1 tasks, System.Boolean& didSomething) [0x00000] at Ansys.ProjectSchematic.Update.UpdateImpl+<UpdateComponents>c__Iterator37.MoveNext () [0x00000] at Ansys.ProjectSchematic.Commands.UpdateComponentCommand+<Execute>c__Iterator4.MoveNext () [0x00000] at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, IExecutionEngineCallback tracer) [0x00000] --- Ansys.Core.Commands.CommandFailedException: Update of the Solution component in Copy of Fluid Flow (CFX) failed: The CFX Solver for system Copy of Fluid Flow (CFX) did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution component. CommandName: UpdateComponent(Component="/Schematic/Component:Solution 1", Force=True) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x00000] at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Int32 milliSecondsTimeout, Boolean exitContext) [0x00000] at Ansys.CFX.CFXCore.Commands.UpdateFromSolverManagerGui.Invoke (Ansys.UI.GuiOperationContext context) [0x00000] at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00000] at Ansys.UI.UIManager+<InvokeOperation>c__AnonStorey35.<>m__1D () [0x00000] at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction) [0x00000] Thanks |
December 14, 2010, 16:01 |
#89 | ||
Yves Delannoy
Rep Power: 16 |
runwb2 $@ I don't use -oglmesa, and setting LANG is no more necessary since ansys12.1.4 (see the release notes: ansys on linux now has localization, I use it in french). I never needed MALLOC_CHECK_=0 . I just run wb2 without options and it works for DM, Meshing and fluent Unfortunately I cannot help you for CFX... |
December 15, 2010, 10:48 |
#90 |
Scott Johnson
Rep Power: 15 |
Thanks for all the help Yankee
December 15, 2010, 15:55 |
#91 | |
Charlotte
Rep Power: 16 |
I have Ubuntu 10.04 64bit and I have exactly the same error... I can open WB, use DM to make a geometry,mesh it. I check CFDPost: it works.
But when I launch CFXPre, I get the same CCL errors than below. When I ran "./INSTALL" I got several messages like: /tmp/ans_install_tmp21311/common/../tcl/wish: Symbol `vmlsAcos4' causes overflow in R_X86_64_PC32 relocation Could it be a tcl problem? The only error I got from the installation is: >>>---------------------------------------> ANSYS installation: Wed Dec 15 03:18:55 PM EST 2010 Revision: 12.1 GC Warning: Limiting number of mark threads >>>---------------------------------------> which normally can be ignored. I contacted the customer portal, and their answer was "we officially support RH4&5 and SUSE Enterprise 10". Argghh, so frustrating. Charlotte Quote:
December 18, 2010, 11:47 |
Ansys 13 error
#92 |
makkemal
Rep Power: 15 |
Ubuntu 10.04
With the steps above 12.1 runs fine in 13 I get the following errors on the same machine QPainter::setFont: Painter not active QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread Anyone seen this Thanks M |
December 20, 2010, 03:29 |
#93 | |
Yves Delannoy
Rep Power: 16 |
I got that in my first tests, but I don't remember what exactly made it disappear. Did you correctly redefine rpm and uname before installing (step 2 of procedure in thread #86)? are you sure that your /etc/hosts refer only once to your hostname (step 3, hostname is obtained with the command hostname)? did you verify that the GL libes from your (maybe proprietary) graphic driver are available (step 7)? If all that is correct, please verify your environement variables (see step 6), and maybe you'll have to remove your .ansys and/or .config/ANSYS in your home dir (but you'll loose all personalizations of ansys). I did all that, and for me it works. |
December 20, 2010, 14:27 |
#94 | |
makkemal
Rep Power: 15 |
Thanks Yankee removing the ~/.ansys and ~/.mc did the trick |
January 4, 2011, 04:16 |
#95 | |
Denis
Rep Power: 15 |
Hi, i've installed ansys 13.0 on a linux machine (debian squeeze 6.0 64bits)
I can't access to the servers licence which are installed on 2 win7 machines. the licence manager give me this: Quote:
January 4, 2011, 04:23 |
#96 | |
makkemal
Rep Power: 15 |
Make sure that ansys is fully installed with the fake rpm and uname script
then sudo apt-get install lsb Pls note this install rpm ass well that is why ansys products has to be installed. Then reinstall on the license manager and it will work Cheers M Quote:
January 9, 2011, 22:24 |
#97 |
Scott Johnson
Rep Power: 15 |
I recently went back to my old computer an re-installed Ubuntu 10.04.1 from scratch (64 bit). I then installed Ansys 13, and once again CFX pre and solver work fine (no CCL errors). I then re-installed the same Ubuntu 10.04.1 from the same DVD on a new partition on my new machine. I then again installed Ansys 13 and got the same CCL errors as before (see post #88).
I installed Ansys before adding any additional software (just like I did recently on my old machine). It is therefore clear that this problem is, at least to some degree, hardware related. Since these particular errors seem to also be limited to Debian based distros, I guess that the issue is with a hardware driver. My best guess is that it is related to my video card. I should note, however, that the problem did not change from when I first installed on my new machine (using some default driver with poor display resolution) and when I installed the proprietary Nvidia driver form my video card (much better display). Either way, the problem remains with my new computer. I should note that my old computer used an ATI video card. Could this issue be related to the Nvidia card drivers for Debian based systems? Can someone confirm this issue on a machine using an ATI video card? Unfortunately, my Linux knowledge is not sufficient to figure out how to further track the issue down from here. Scott |
January 10, 2011, 02:17 |
#98 | |
makkemal
Rep Power: 15 |
ANSYS expects to find libGL.so.1 in /usr/lib/.
The following solved my problem: For Nvidia drivers sudo ln -s /usr/lib/nvidia-current/libGL.so.1 /usr/lib/libGL.so.1 For Mesa drivers sudo ln -s /usr/lib/mesa/libGL.so.1 /usr/lib/libGL.so.1 Quote:
January 11, 2011, 11:58 |
#99 |
Charlotte
Rep Power: 16 |
I have an ATI card and I have the CCL errors. so I guess the CCL errors are not linked to the graphic card...
January 11, 2011, 14:07 |
#100 |
Scott Johnson
Rep Power: 15 |
Makkemal - Thanks for the pointer. I will try this next time I am able to boot into Linux -- I am running CFX in Windows right now .
Charlotte - Thanks for the info. |
LINUX Experts: Help with installing ANSYS workbench | faisal_durr | ANSYS | 1 | May 30, 2014 08:07 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 12:59 |
How can I start the ANSYS 12 workbench in LINUX | Ardisia | ANSYS | 3 | September 7, 2010 00:19 |
ANSYS Workbench on Linux | CPUcruncher | ANSYS | 4 | July 11, 2010 09:19 |
ANSYS Workbench on "Certified" linux distro | mechanicaldesign | CFX | 0 | April 16, 2010 01:56 |
