Post Processing free surface flows
Old   February 13, 2008, 11:35
Default Post Processing free surface flows
Chris Wetton
Hi, im currently simulating the Dam Break Problem using the VOF method in CFX. However I am having a problem in post processing with seeing my results. I have created a plane volume in box (used to model the dam break problem) yet only seem to see fluid at the edges of this. I have put a second plane in the centre of the box to check there is fluid which works, however I want to simulate the fluid as a whole. Any help would be appriciated. Chris
Old   February 13, 2008, 15:02
Default Re: Post Processing free surface flows
UnderwaterAlex
Hi Chris,
Add a Volume location and change method to Isovolume, set variable to Water.Volume Fraction, value to .5, and change mode to "above value". That should give you the idea, then you can play with the options to get it just right. Also, you can change the contour colormap to "blue to white" for planes, etc to get it to look like water as well. I hope this answers your question.
-Alex
Old   February 14, 2008, 09:14
Chris Wetton
Hi Alex, thanks for that good news is it works so now just having a play with it to try to make it less "blocky" to create some cool looking animations. Thanks again. chris
Free Surface Flows...>>> Please Help..! sushii FLUENT 23 February 28, 2013 02:29
Free Surface Modell & stratfied Flows Zaktatir CFX 2 January 11, 2010 12:24
High Reynolds Free Surface Flows Ferreira Main CFD Forum 3 September 28, 2005 03:45
Free surface flows with solid transport Patrice Jaumouillie CFX 3 November 5, 2001 10:31
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 22:03
