February 13, 2008, 06:31 |
A problem with blocks in Icem
Hello
I'm a beginner with Icem, im currently using it in my BSc thesis. I've come across a problem I can't solve. Please look at this image: http://img85.imageshack.us/my.php?image=needhelpxr7.jpg You see how the lines from block 1 bends down to fit into block 2? Like Block 2 is the master and the block 1 is the slave. I've adjusted the number of nodes to 4 in the premesh-params on the vertical edge of block 2(the one marked with edge in pic). But I want it to automatically adjust itself the block 1 instead, so block 1 becomes master and block 2 slave. Is there such a feature in Icem? Would appreciate it much if anyone could explain how I can accomplish this! Best regards from Sweden |
February 14, 2008, 08:59 |
Re: A problem with blocks in Icem
Hello Janne,
I cannot see your image (imageshack is not accessible here at work) but many problems I've encountered with ICEM Hexa are related to bad associations of edges/points. The first thing to do would be to check these. I don't know if this helps but it's the best I can say without looking at your specific problem. Regards, Felix |
February 21, 2008, 09:37 |
Can you show me your geometry section as whole....let me see whether i can sort it out. Sam
ICEM - strange linking problem | RodriguezFatz | ANSYS Meshing & Geometry | 3 | October 25, 2011 04:25 |
[ICEM] Problem with volume mesh in ICEM CFD | kolapoasafa | ANSYS Meshing & Geometry | 2 | September 16, 2011 04:54 |
Icem 12.1 - distance problem | sys999 | ANSYS | 2 | January 20, 2011 08:54 |
Region Problem with ansys 12 icem mesh for cfx | compizer | CFX | 0 | May 5, 2010 04:02 |
Problem exporting big meshes from ICEM to Fire | Emil | CFX | 0 | October 10, 2008 14:06 |
