Water-air interface
Old   February 12, 2008, 22:24
Default Water-air interface
Ken
Dear all,
I am creating a 3d tank in CFX and hope to apply in current flow to the tank, and later some waves. Ultimately a cylinder will be placed in the tank to find the forces, etc. But firstly, i need to know how to let CFX knows that there is water and air in my geometry model. I saw CFX Tute 16 where they used volume fractions for the gas-air flow but i still do not understand how to apply that to my model.
Or is there another easier way out?
Hopefully you guys can help me out on this.
Thank You. Kwong
Old   February 13, 2008, 14:48
Default Re: Water-air interface
UnderwaterAlex
Did you try the free surface flow over a bump tutorial? Check that one out, it has air and water. To answer your question, you change the parameter "fluid list" under Domainefault Domain (assuming you haven't named your domain anything different) to include both air and water. You'll also need to initialize the domain with the appropriate values for air and water volume fraction using a step function in CEL. Definitely check out the free surface tutorial.
Hopefully that helps...
-Alex
Old   February 19, 2008, 10:25
black jack
Leave it! Go for shopping!
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Heat Transfer Coeff on the water air interface Anton Main CFD Forum 3 June 2, 2010 02:49
Setfields inoutlet and water and air patches erik023 OpenFOAM Pre-Processing 1 September 29, 2008 11:05
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 08:04
Air and water simulation Mavinakere Siemens 1 February 27, 2002 23:35
