how 2 freeze 1 phase flow field & start lagrangian
Old   February 12, 2008, 15:38
Default how 2 freeze 1 phase flow field & start lagrangian
KK
I solved single phase flow field with LES and now I want to inject particles of different sizes.
Is there any way to 'freeze' single phase flow field and track the particles of different types? By freezing I mean that I want to stop solving single phase flow field (carrier fluid) and use that flow field to track my particles. It will save my computational time.
Old   February 12, 2008, 17:33
Default Re: how 2 freeze 1 phase flow field & start lagran
Yes, this can be done. Set up a simulation with 0 set as the maximum iterations (or you might need to do one iteration just to keep it happy) and do an uncoupled particle tracking on the result of that.
Alternately you can stop the solution of various solvers (eg Velocity/pressure, enthalpy, scalars, turbulence) individually using expert parameters.
Old   February 12, 2008, 18:31
Default One clarification please
KK
Thank you Glenn.
In first approach, did you ask me to define maximum time steps? (I am doing LES and hence transient). Or does it mean zero (or one) iteration in steady state solver taking solution from LES as initial guess?
In short, I am confused 'iteration' Vs 'time step'. Please clarify.
Old   February 13, 2008, 17:24
Default Re: One clarification please
If you just want a particle track based on a frozen flow field from an LES simulation, do a steady state simulation with zero iterations and uncoupled particle tracking. I think this should work.
Old   February 13, 2008, 17:40
KK
Thank you very much Glenn. I will give it a try.
By the way, I can imagine that liquid-solid particle simulation with Eulerian-Eulerian approach with LES model would be extremly costly in terms of computational resources. (Assuming we have variety of particle's sizes)
Do people do these type of simulations? Or is it not feasible at all to do in terms of time consumed?
I will be thankful to you for any of your comments on it.
Old   February 14, 2008, 17:48
Yes, multiphase modelling will significantly increase the cost of an LES mode. The expense of a LES model is also strongly dependant on the Re of the flow. Low Re are not too bad as the turbulent eddies you have to resolve are large. For high Re flow you need much greater resolution. This is the primary factor influencing the size of an LES simulation.
Whether it is feasible depends on how big a simulation you need to run to get useful results, how big a computer you have access to and how long is your patience.
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 08:59
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 09:10
