Number of particle positions in Lagrangian model
Old   February 11, 2008, 21:11
Default Number of particle positions in Lagrangian model
KK
I want to use Lagrangian model for particle tracking in Transient simulation using one way coupling in between solid particles and fluid. Hence solid particles will be insterted at the last time step.
I have to specify 'Number of Positions' of the these particles and one option given in CFX-Pre allows to set particles per second(called 'Direct Specification'). Suppose I want to track 1000 particles at once, then, do I need to divide it by my time step (say 0.0001 sec) in order to get sensible number of particles per second? I am worried if I mention 1000 particles and if solver divides it by time step then only one particle will be tracked. If it does not calculate that way then I should not specify 1000/(time step).
Please help.
Thanks, KK
Old   February 12, 2008, 06:08
Default Re: Number of particle positions in Lagrangian mod
Elisabetta
Hello KK,
don't think that the number of particle is divided by your timestep.
Regards
Elisabetta
Old   February 12, 2008, 15:31
KK
Thank you very much Elisabetta, I specified 10^5 partciles under 'Direct Specification' (CFX-Pres shows unit to be per second) and my time step was 0.0002 seconds. I noticed that the solver was injecting 20 particles per time step. That makes sense that total number of particles injected in one second would be 10^5. is it correct?
Old   February 13, 2008, 06:33
Elisabetta
Yes I think it is correct.
Ciao
Elisabetta
Old   February 16, 2008, 05:56
Default Re: Number of particle positions in Lagrangian mod *NM*
Roghayyeh Motallebzadeh
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 20:00
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 18:54
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
How to properly specify number of positions for pa Piti CFX 2 January 12, 2008 12:11
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
