MAxium residual...confusion with expert parameter
Old   February 7, 2008, 17:49
Default MAxium residual...confusion with expert parameter
KK
I want to know the location of higher residuals in my domain. The manual (modeling guide v11 page 394) talks about some expert parameter 'output eq residuals' which I am not able to see in the chapter 'Expert Control Parameter' from the same manual.
1) Is this expert parameter available ? What will it do ? (will it write location of max residual to .res file?)
2) I see another expert parameter 'monitor residual' ? Does it write residual and location to *.out file or *.res file?
Thanks, KK
Old   February 8, 2008, 01:20
Default Re: MAxium residual...confusion with expert parame
Harshad
The location of maximum residual for each equation is printed anyway at the end of output file.
Old   February 8, 2008, 03:06
Default Question rephrased in better words
Kk
Hi Harshad, Thanks for your reply. I wanted to know
1) Can I know the location of maximum residuals WHILE the simulation is running? If yes, how?
2) The location that you talked about, just tells about ONE location of maximum residuals. I wanted to know if some how I can create volumes in CFX-Post [Location-> Volume (type -isovolume)] to see the regions of higher residuals (To decide if they are in my region of interest). For that I want to know how to right residuals in result file.
And it would be really great if you can clarify the two expert parameters I mentioned in my first post in this thread.
Thanks again, KK
Old   February 8, 2008, 11:47
Default Re: Question rephrased in better words
Phil
On the output control form, select 'Output Equation Residuals'. Or set the expert parameter 'output eq residuals=t'. Both work.
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
