2 Domains share their walls...any interface ?
Old   February 7, 2008, 16:49
Default 2 Domains share their walls...any interface ?
KK
I have two fluid domains sharing their walls in some region (walls overlaps each other). They do not have any mass OR energy transfer acroos the walls. Hence I simply have been defining both the faces as wall. Do I still need to create some interface for both the faces creating walls?
Thanks.
Old   February 7, 2008, 17:28
Default Re: 2 Domains share their walls...any interface ?
No, but you will need to define the wall twice. Once for each domain.
Old   February 7, 2008, 17:34
KK
Thanks Glenn.
KK
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Defining UDS at interface, Boundary Zone Walls Sliding Mesh jalarron Fluent UDF and Scheme Programming 0 June 23, 2010 05:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
