ERROR: Floating point exception: Overflow
Like Tree10Likes
Old   April 13, 2018, 06:35
Question Floating Point Exception Erroe
  #21
Vipul Parmar
vipulparmar174 is on a distinguished road
Hello!
I'm trying to study the flow path of Charge in the engine and in that for moving piston I have to give dynamic meshing to the piston but the solver will not solve it completely when the crank angle reaches to 191.5 degree it will stop solving and the dialog box with a message will open and it says negative dynamic cell zone created and after that the solver will not solve it further.
Please, anybody, help me out how to solve this problem.
vipulparmar174 is offline   Reply With Quote
Old   April 13, 2018, 09:45
FAQ: https://www.cfd-online.com/Wiki/Ansy..._went_wrong.3F
But I have done a lot of IC engine modelling so in your case I suspect you find that CFX can stretch a mesh well but it is poor at compressing it and often results in folding meshes. The easiest way I found to avoid this is by starting the simulation at TDC and that way you only ever stretch the mesh and never compress it.
That TDC trick works on any version of CFX. I understand recent versions of CFX have some new mesh motion options which may also help but I have not looked into them.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   July 14, 2018, 02:19
Default ERROR: Floating point exception: Overflow
  #23
JINOOP
anjinoop is on a distinguished road
Dear All,
I am using CFX for supercritical co2 fluid. I am using polynomials for properties and data is taken from NIST database
I am getting the above mentioned error. But error disappears when i use any other default fluid.
Please help in this regard
Jinoop
anjinoop is offline   Reply With Quote
Old   July 14, 2018, 07:57
The negative volume element error has nothing to do with the fluid. It is just that the mesh has turned inside out. If changing the fluid affects this, then you must have some coupling to the fluid, maybe FSI, rigid bodies or something similar.
the problem of my transient simulation "Floating point exception: Overflow " alloveyou CFX 15 November 22, 2012 12:14
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
Error : floating point exception; overflow. maryam CFX 3 May 18, 2010 08:44
Floating point exception: Overflow? mike CFX 4 December 15, 2009 18:30
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
