new user, and i want to know somethings
Old   February 7, 2008, 08:35
Default new user, and i want to know somethings
José
Hi! I´m a new user of CFX. I want to make a simulation with cfx. about a tank with water inside. I want to know if i can define the materails of the tank the for example, concrete or steel.
And what is the best example to made, to praticise.
Because at now, i can´t put water inside the tank!
How i do this?
Thanks!
José!
Old   February 7, 2008, 14:31
Default Re: new user, and i want to know somethings
UnderwaterAlex
Hi Jose,
You can define the materials of the tank or the properties of that material, but why do you need to? Is it for heat transfer, fluid-structure interaction, wall roughness effects? The answer to that question would help figure out how to best incorporate this info into the simulation (or if is necessary at all.)
As far as a two-phase simulation, I suggest carefully going through the tutorial on free surface flow over a bump (it's #7 on CFX-11). This should give you hints on how to get started.
-Alex
Old   February 25, 2008, 11:53
jose
hi!!
I want to make a tank with water inside and i want to know if is possible introducer to it the the moviment of sloshing to the water, and retired the force in the base of the tank!
tanks.
josé!
collect User Experience about CFD softwares dxw_CFD Main CFD Forum 12 October 24, 2011 23:08
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 19:37
CFX 10 User Routine NOT in Fortran Andre CFX 14 August 9, 2006 00:03
particle user routines Felix CFX 1 July 24, 2006 13:32
User Surface, Calculator Christian Bruzzese CFX 3 November 15, 2005 11:13
