LES of Non-Premixed Combustion in CFX??
Old   February 3, 2008, 09:14
Default LES of Non-Premixed Combustion in CFX??
Manu
Hi Robin and Glenn, Just curious to know why i cant combine LES Samagorisky Model and Eddy Dissipation Model for a non premixed combustion problem in CFX? Is CFX unable to do LES for such problem? However support says SAS is capable enough to give results like LES. But i am not satisfied. Can you please throw some light on it. Thanks in advance.
Manu
Old   February 3, 2008, 17:35
Default Re: LES of Non-Premixed Combustion in CFX??
I have no experience in using the Eddy Dissipation model in LES, but I can't see why you can't use it with LES. What is telling you that you cannot use it?
Old   February 4, 2008, 04:09
Manu
Hi Glenn, When you select both( EDM and LES) of them and press ok. After that if you reopen to see whether they are there or not i always find k-e has replaced the LES Samagosrinsky model. This is what the problem is. regards Kirti
Old   February 4, 2008, 17:30
I would talk to CFX support about this. It may be a bug in CFX-Pre. You can tell the solver to use EDM and LES via the CCL anyway if you want to over-ride CFX-Pre.
Regards, Glenn Horrocks
Old   February 22, 2008, 12:18
Rumors
In their standard formulations these models are not combineable. The reason is not a bug in CFX but the theory of both models. Have a look at the theory manual of CFX or the literature (famous old paper of Spalding). The EDM reaction rate depends on turbulent kinetic energy and its dissipation. How do you define these quantities in LES?
Old   February 25, 2008, 17:34
Good point!
Premixed combustion model - FLUENT Mowan FLUENT 10 September 23, 2023 02:56
urgent!!! please...about Premixed Combustion mesinUGM FLUENT 6 March 30, 2012 10:22
Non-adiabatic Premixed combustion through scriptin Mahesh Main CFD Forum 2 April 1, 2007 02:04
LES - Premixed combustion. Interested. Main CFD Forum 9 July 16, 2005 08:09
Does CFX support LES, local dynamic mdoel JJ CFX 0 August 28, 2003 22:15
