January 29, 2008, 16:57 |
Blocking in ICEM
Hi
What is the difference between deleting the block to tell ICEM that it is solid surface and its not suppose to mesh it, and creating part (create part with blocks) and then moving it VORFN. In either case we get a solid object so there is no difference right? CFD newbie |
January 30, 2008, 09:58 |
Re: Blocking in ICEM
It's the same, yes. You can extract "deleted" blocks, by moving them from VORFN.
January 30, 2008, 13:46 |
Thank you Dr. Squad.
CFD newbie |
January 31, 2008, 10:01 |
If you want mesh propagations to be the same either side of a deleted block without having to set it on each block separately; then move the block to be deleted into VORFN.
[ICEM] Using Blocking with ICEM (infinity lines appear) | Touré | ANSYS Meshing & Geometry | 6 | August 5, 2012 18:07 |
No Blocking tab in Ansys ICEM CFD11.0 | NewGuy | CFX | 1 | November 22, 2010 16:38 |
Ansys ICEM 12.0 Searching for tutorial information on complex 3d blocking | Raoul | ANSYS | 1 | October 18, 2010 07:08 |
ICEM blocking | Chris Wetton | CFX | 6 | March 9, 2008 06:18 |
ICEM Blocking 2D and Fluent error | Dr. Flow Squad | FLUENT | 3 | March 5, 2007 03:27 |
