convective boundary condition
Old   January 25, 2008, 09:08
Default convective boundary condition
Mani
Hi
Can anyone tell me what on earth is convective boundary condition and how can i impose it at the outlet of my model. Thanks
Mani
Old   January 28, 2008, 18:24
Default Re: convective boundary condition
It is normally used on a wall boundary condition to model heat transfer from the wall. It is not usually used at outlets.
Old   January 28, 2008, 18:36
Mani
Well in the paper that i have infront of me they have imposed this BC at the outlet. How can i use it in CFX anyway.
Mani
Old   January 29, 2008, 19:33
I have no idea. I can't see how imposing a convective heat transfer condition on an outlet can have any physical basis. The fluid exiting an outlet depends on the temperature upstream.
Old   January 29, 2008, 19:34
Are you sure they were not applying a thermal radiation boundary condition? You can apply this type of boundary on an outlet in CFX.
Old   January 30, 2008, 04:29
Andreas
Convection means something (mass, momentum, heat, concentration) is transported by the fluid; this is described by the term "div(rho u Phi)" where rho is density, u is velocity and Phi is what is transported. CFX has this convective boundary condition at outlets: for mass and momentum if you set pressure there, and for heat and concentrations this is automatically set (you cannot choose e.g. a temperature at an outlet). There comes a difficulty if pressure fluctuations reach the outlet since they can be reflected there so that the outlet is not fully "convective"; for this, try the beta feature "non-reflecting boundary conditions".
Old   January 30, 2008, 07:13
Mani
Thank you Glenn & Andreas. How can i use "non-reflecting boundary condition" which i suppose is same as "convective BC". The purpose in either case would be to prevent pressure fluctuations reflecting back in flow domain right.
Mani
Old   February 2, 2008, 17:25
Mani
Ok i understand now what you meant Andreas. Thank you
Mani
Old   March 21, 2017, 10:59
Hamed
Hamed1117 is on a distinguished road
non reflecting boundary condition in OpenFoam is almost the same to convective one,
see this link !
http://caefn.com/openfoam/bc-advective-wavetransmissive
Hamed1117 is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Convective boundary condition andrea_barbera OpenFOAM Running, Solving & CFD 4 March 4, 2010 05:36
Convective Boundary Condition garni FLUENT 0 September 25, 2005 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Convective boundary condition STN Main CFD Forum 5 May 29, 2002 09:47
