can use other shape of mesh instead of triangle?
Old   January 24, 2008, 03:32
Default can use other shape of mesh instead of triangle?
wan
Im using CFX mesh to do meshing. How can i set streight line meshing instead of triangle?
Old   January 24, 2008, 05:34
Default Re: can use other shape of mesh instead of triangl
Gen
There are only tetrahedrons and inflation triangle prisms (for a boundary layer) in CFX-Mesh . You can try to use other methods of WB Mesher (e.g. hexdominant). But for regular structured hexa mesh you should apply ICEM CFD.
Old   January 24, 2008, 17:31
Gen's answer is not complete. CFX supports tets (4 nodes), pyramids (5 nodes), prisms (6 nodes) and hexas (8 nodes). No other element type is supported.
Old   January 25, 2008, 00:27
CycLone
You can also create hexehedral meshes in Workbench Meshing by using the sweep method. This is most likely what you are looking for.
-CycLone
Old   January 29, 2008, 03:25
Wan
Thank you Cyclone,
Can you give me more information on sweep mathod? Appriciate your advice.
warmest regards, Wan
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[Other] Dynamic Mesh Changing Shape dancfd OpenFOAM Meshing & Mesh Conversion 1 June 13, 2010 23:09
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
Mesh Mignard FLUENT 2 March 22, 2000 06:12
