Viscosity for solid in Gas-Solid Two-phase Flow
Old   January 23, 2008, 12:00
Default Viscosity for solid in Gas-Solid Two-phase Flow
jakjak
Quoting from CFX-11 Modelling Guide: <blockquote style="padding-top:1em; font-family: courier"> "... In such problems (Gas-Solid Flow), you should assign the solid phase a small insignificant molecular viscosity. This is permissible, as the physics are dominated by inter-phase drag and turbulence effects. ..." </blockquote>
I was wondering what is the reason behind assigning a "small insignificant molecular viscosity"? I would think that a more viscous "fluid" would represent more a solid than one that is less viscous.
Any thoughts?...
Old   January 23, 2008, 18:32
Default Re: Viscosity for solid in Gas-Solid Two-phase Flo
CycLone
This viscosity represents the diffusion of momentum across the solid phase (i.e. the diffusion of momentum from high velocity particles to low velocity particles, as though they were molecules in a fluid). Since the solid velocity is mostly determined by drag forces, this viscosity has little effect on the solution but may affect numerics and convergence.
-CycLone
Old   January 30, 2008, 01:44
shehab abdelrahman
hi there: found your discussion and wanna ask a q. what if using solid phase with a liquid carrier is it still needs to assign a viscosity for the solid. thanks,
Gas solid flow in a pipe with 90 bend pandaba FLUENT 0 September 14, 2010 02:43
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
liquid and gas flow faouzi FLUENT 3 July 10, 2001 10:52
