how to make turbine blade in Ansys Blademodeler
Old   January 18, 2008, 11:36
Default how to make turbine blade in Ansys Blademodeler
Usman
Hi, I have three radial sections of a turbine blade (at hub, mean and tip). How can i make full 3D blade out if it in Blademodeler. Kindly also tell if i mesh the turbine geometry in TurboGrid, can i export it to Fluent for CFD analysis. Many Thanks,
Old   January 18, 2008, 13:39
Default Re: how to make turbine blade in Ansys Blademodele
Usman
Hi Usman
Regarding your second question you should be able to do that! I have never done it though.
Regards Usman
Old   January 22, 2008, 05:17
Pankaj
Hi Usman!
There are some examples of bladegen files stored in your root directory(else search for .bgd files)which can give you some idea about how to make a turbine blade.
Old   January 29, 2008, 05:53
spoorthi
please help in simulating a wind turbine blade in 6 DOF ????.... usman naseer Main CFD Forum 2 March 10, 2016 03:53
conjugate heat transfer of a turbine blade Steven-GY FLUENT 1 February 23, 2013 15:31
[ANSYS Meshing] Mesh elements inside turbine blade eoinsturbine ANSYS Meshing & Geometry 2 May 15, 2011 12:44
[Other] ANSYS CFX-Meshing problem of a wind turbine blade Zoe ANSYS Meshing & Geometry 1 July 14, 2010 03:02
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 11:18
