compressible flow in CFX!
Old   January 12, 2008, 20:20
Default compressible flow in CFX!
Ihsan
Hi guys
I am new to CFX! Can we simulate a compressible flow in CFX with lower velocity. Fluent had an option where we could specify whether we want our flow to be compressible or incompressible. Is there such option in CFX? How can we simulate a compressible flow in CFX? Thanks in advance for your answer!
Old   January 13, 2008, 01:29
Default Re: compressible flow in CFX!
Jia Li
As I know, two things shall be concerned:
1. The material must be density changeable, such as "Ideal Gas"
2. If you model heat transfer, "Total Energy" option should be select.
You can refer the help documents at : ANSYS CFX-Solver Modeling Guide | Basic Capabilities Modeling | Physical Models |
Old   January 13, 2008, 04:27
Jack
If you choose Ideal Gas Air as your fluid, it will be a compressible simulation.
Old   January 13, 2008, 12:57
Mann
I am interested in Simulating acoustic (sound) in CFX with LES. For that my simulation will have to be compressible. Is it possible to do that in CFX. If yes how? Thanks in advance
Old   January 13, 2008, 19:42
Jack
Hi! Mann, I think so, although I never done it before. CFX is a very powerful package. Please tell me how to do that when you find out. Thanks
Old   January 14, 2008, 06:43
Mann
Ok no worroies Jack!
Mann
Old   January 14, 2008, 17:35
CFX definitely can model sound (acoustic) waves in air, I have done it many times. CFX solves the full viscous compressible navier stokes equations but for most acoustic applications a far simpler equation set without viscosity and a reduced linear wave model works well, and therefore CFX is overkill.
What are you trying to achieve with acoustic modelling? What type of acoustics is it? I should point out that the acoustics work I did had pressure waves of sufficient magnitude that the waves are no longer linear so the simple assumptions of general acoustic software was not applicable.
Old   January 14, 2008, 17:57
Mann
Hi Glenn
My supervisor has asked me to look into acoustic and LES. We are interested in simulating some sort of acoustic with LES. Thats why he asked me to investigate if it will be possible with CFX. Can i ask what type of acoustic work did you do and what code did you use for it. Can you send me any of the work that you did or some other relevant information. Thank you
Old   January 15, 2008, 17:56
My PhD work was modelling an internal combustion engine and an important part of that is the pressure waves in the manifolds. You can see my thesis on the web at http://hdl.handle.net/2100/248
Yes, CFX can do acoustics and LES. Whether what you are trying to do can be done on anything smaller than a supercomputer and several years computational time will depend on what you are trying to model.
Old   January 15, 2008, 19:50
Mann
Ok Thanks for the link Glenn. I will look into it! I will get back to you if i need to ask you something else. I hope you wont mind!
Mann
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 07:30
Outlet pressure for compressible flow Michelle CFX 12 September 1, 2015 19:38
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
compressible flow maria teresa FLUENT 1 September 7, 2007 17:58
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 05:22
