I am running an unsteady simulation of flow past a 2D circular cylinder. I wanna know the way to calculate Drag force per unit length (D/length) in CFX-post. Thanks Farid |
Calculate the drag. Divide by the length.
can you tell me for drag calculation which function I should use? |
Hi Mohammad,
You can use: force_x()@boundary or force_y()@boundary or force_z()@boundary You may need to do some trig to align it with your direction of motion if it isn't aligned with an axis. Replace "boundary" with the name of your boundary region or a surface group which includes all the relevant surfaces. -CycLone |
adel
Rep Power: 0 ![]() |
hi every body
can help me about calculate drag cofficient and terminal velocity in a cyclone in fluent thank you |
Am i right? porous jump drag force | Shim | FLUENT | 2 | August 25, 2014 09:33 |
Force vectors for drag during sweeping motion | aamer | FLUENT | 0 | April 18, 2011 08:17 |
exporting drag force from fluent | fluentguy | FLUENT | 2 | October 27, 2009 14:19 |
Particle drag force | RE13 | FLUENT | 1 | February 26, 2008 14:55 |
Airfoil Drag Force | wowakai | Main CFD Forum | 3 | October 13, 1998 19:27 |
