January 9, 2008, 16:21 |
file with data of temperature and time
I am making a numerical simulation in the CFX-v5.6, of a solid with heat flux in one of the sides, in the transient heat conducting, for a total time of 100 [s] (it is not the time of cpu), with timestep of 0.1 [s]. I want to monitor the temperature distributions in 4 points (x, y, z) different, and of course, of the solid, called of points 1, 2, 3 and 4. How to make that the CFX v5.6 creates only one file of text or of the type .dat with the temperatures in each timestep for each point? I already created points 1, 2, 3 and 4 and already I made the chart of Temperature [K] (in each point) versus Time [s] in the CFX-Post (bmp file), but I wanted to make the chart with the numerical data of the temperatures in each point and for each timestep in the Excel software and later making a comparison with experimental data! The file would be thus, of Temp100.dat name: 0.0 29.000 29.000 29.000 29.000 0.1 30.132 31.999 33.142 31.935 0.2 31.372 32.120 33.154 32.112 0.3 33.418 33.210 34.332 33.234 0.4 34.655 34.532 34.452 33.345 ..... ...... ........ ....... ...... 100.0 123.122 134.342 117.543 121.486 PS: all the data would be in only one file! Thanks! Rogério Fernandes Brito. |
January 9, 2008, 16:52 |
Re: file with data of temperature and time
Two ways: You can do it in the simulation using a monitor point. Then you can export the data from the solution (even as it is still running). You can do it in post processing in CFX-Post by creating a point and exporting the data at that point. As you have transient data you will have to do a little script to cycle through the timesteps and export the data. Glenn Horrocks |
January 9, 2008, 17:10 |
I´ll think about it! Thanks for the moment!
"Hi, Two ways: You can do it in the simulation using a monitor point. Then you can export the data from the solution (even as it is still running). You can do it in post processing in CFX-Post by creating a point and exporting the data at that point. As you have transient data you will have to do a little script to cycle through the timesteps and export the data. Glenn Horrocks" |
January 9, 2008, 19:00 |
How about this?
http://rogeriofernandesbrito.googlep...he_tempera.jpg Is this a good option? Rogerio Fernandes Brito. |
January 10, 2008, 17:44 |
That should do the trick. Glenn Horrocks |
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 09:45 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
