January 8, 2008, 14:48 |
doubt on creating a chart
How to create a chart like temperature [K] versus time [s] in a specified point of the solid domain? My simulation type is transient with 0.1 [s] as the timestep, with 100 [s] of total time (not CPU time).
I´m using Ansys CFX-v11.0 and CFX-v5.6 too. |
January 8, 2008, 17:11 |
Re: doubt on creating a chart
Hi!
This sequence work for me: 1.You have to create a point in the specific location to study. 2.Under "Chart" tab (details vew, left-down window), select type>time. 3.In the same window Select the "Chart Line 1" tab, method>Point. 4.(same window) Select Location>"your point name". 5.(same window) Select (Time Variable)Varible>Temperature (or any other variable of your interest depending on time) 6.Finally click apply and if necessary click "refresh" over the chart viewer. I hope this could help you. By. |
January 8, 2008, 18:19 |
Thank you very much! It did work out! Gracias!
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 16:33 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 18:51 |
Creating a Velocity Chart | S.Beta | CFX | 1 | January 29, 2010 14:43 |
Creating chart in cfx-post | Az | CFX | 1 | October 22, 2008 08:06 |
Problems with Meshing: Collapsed Cells | Emmanuel Resch | Siemens | 1 | July 30, 2007 04:02 |
