how to set two bubbles using VOF method
Old   January 7, 2008, 07:41
Default how to set two bubbles using VOF method
xujjun
I want to simulate the bubble using VOF method in CFX10.0,i have simulated the single bubble,but I want to know how to set two bubbles in initial boundary condition,,any help will be appreciated. thanks in advance
xjj
Old   January 7, 2008, 18:15
Default Re: how to set two bubbles using VOF method
You can use the CEL expressions to define regions of fluid and gas. Either use a step function or a 3D interpolation function (cloud of points).
Old   January 8, 2008, 08:51
pankaj
Hi xujjun!
can u pls help me to formulate a steady state problem of multiphase for a single bubble in cfx?
Old   January 8, 2008, 22:54
HK
Hello, 1) Did you check the steady state terminal settling velocity compared to some theoretical calculation?
2) Did you monitor the recirculation of air inside the bubble?
HK
Old   January 9, 2008, 07:08
xujjun
Thanks,Glenn Horrocks,how to set the initial condition of the two bubble,i think that the two different regions on the bubbles need to set, i do not know that whether the subdomain region is used or not.
Hi,pankaj, I simulated single bubble using transient method, I am sorry i do not know how to simulate single using steady method.
Old   January 9, 2008, 07:16
xujjun
Hi,HK, i will compare the terminal settling velocity with some theoretical calculation, but there are few numerical results because of the too many time of the completing a case.
Old   January 14, 2008, 06:55
Andreas
You do not need subdomains for this. Use e.g. the sum of step functions as initial condition for the volume fraction of one phase:
step(((2. [mm])^2-x^2-y^2-z^2)/1. [m^2])+ step(((2. [mm])^2-x^2-(y-6. [mm])^2-z^2)/1. [m^2])
Then, two spherical bubbles with radius 2 mm are at x=y=z=0 and x=z=0, y=6 mm. Perhaps a piecewise linear step funtion (or a tanh function) is better than this discontinuous step...
Old   January 14, 2008, 07:23
xujjun
thanks Andreas, i will try using your method. recently, i simulated a single bubble of quiescent water in a closed tank using vof model, however, i found the volume fraction of bubble is decreasing with increasing time, the interface of bubble is blurry,even to disappear, my mesh is very good and the number of the meshes in a bubble is about 20, i think the mesh is very enough, i do not know how to do ?
calculating Normal vector in level set method amir2920 Main CFD Forum 1 July 21, 2009 08:25
Fluent VOF Method - At a total loss advice required please LSF Main CFD Forum 5 April 13, 2009 22:56
using level set method rubby Main CFD Forum 2 March 7, 2009 03:02
Level set method for detonation Amir Main CFD Forum 1 July 2, 2008 16:25
VOF method on inter-tank transfer Louis FLUENT 0 March 14, 2006 10:28
