Graph plot between Pressure ratio and constant span
Old   May 12, 2023, 09:38
Default Graph plot between Pressure ratio and constant span
Sushil chaudhary
sushil1151 is on a distinguished road
Does anyone have an idea how to calculate the inlet and outlet pressure at constant span (Lets say at 0.2,0.4,0.6,0.8,1.0)?
If I am able to calculate the inlet and outlet pressure at given span then I will be able to calculate the pressure ratio and plot the graph between pressure ratio and normalized span. Please help me out.
CFD analysis of axial flow compressor
I'm using ANSYS CFX - CFD POST
sushil1151 is offline   Reply With Quote
Old   May 15, 2023, 04:50
Yuanhua Liu
Sunkey is on a distinguished road
Many ways to do this. For me, I prefer this way:
Insert two Plane at some axial position you like as inlet and outlet.
Locatio-ISO clip
select the plane you interted, select the virable "Radius", insert the uppon bound and the lower bound. For example, the hub is at R = 0.1 and the shroud is R = 0.2, so the 10% span is Radius>= 0.1 and Radius <= 0.11
It is more efficient to use CCL in command editor
Sunkey is offline   Reply With Quote
ansys 11, axial compressor rotor 37, cfd - post, turbo machinery
Absolute pressure not increasing in closed volume with a constant heat source trashcan ANSYS 7 November 12, 2024 21:48
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
fluid flow but temperature raises from nowhere? mxcfd STAR-CCM+ 5 September 16, 2014 06:46
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
