December 19, 2007, 09:26 |
Exporting results from CFX to ANSYS ??
Dear friends,
I am trying to run a 2-way coupled Fluid structure interaction problem in ANSYS. In this case, as you know, both ANSYS and CFX solver starts same time. I wanted to transfer pressure, temperature and wall heat transfer coefficients from CFX to ANSYS( in a transient mode). But when I introduce the interface between fluid and structure for transformation of results in this 2way coupled simulation e.g. by defining a wall between fluid and structure and saying: Mesh Motion- Option: ANSYS Multifield, Receive from ANSYS: total mesh displacement, ANSYS Interface: FSIN_1, Send to ANSYS: Total force and Heat transfer- Option: ANSYS Multifield, Receive from ANSYS: wall heat flow, ANSYS Interface: FSIN_1, Send to ANSYS: Temperature, It gives me following ERROR: ""Export results are unavailable as no suitable boundaries exist for use as export surfaces. Mesh motion on a boundary invalids its use as an export surface."" Thanks Sohail Germany |
December 20, 2007, 02:10 |
Re: Exporting results from CFX to ANSYS ??
Check if solid-fluid interface surfaces are matching exactly. Any difference between them can cause this error.
Best luck, Chirag |
Compressible Flow in Ansys CFX | bcheruk | CFX | 15 | July 6, 2017 07:30 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 10:16 |
Ansys 13 CFX problem on LInux Opensuse 11.4 | serendipity | CFX | 10 | August 7, 2012 04:24 |
CFX cylinder or sphere benchmark results | Mel | CFX | 1 | August 8, 2005 19:47 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
