Multiphase Euler-Euler / gas solid
Old   November 27, 2007, 05:24
Default Multiphase Euler-Euler / gas solid
Dr. Flow Squad
When doing a gas solid euler-euler setup withn CFX PRE I choose "air at 25C" as the continuous phase. When I specify my "solid" material, I'm aware of I should use a continuum phase for the solid part. But should I choose a "material Group" = "Constant property gases" for the dispersed solid phase or should I choose "Constant Property Liquids"? What's the difference? What I have done is taken the data for water and altered them to my need by specifying the proper density and reduce the viscosity to 1e-12.
Old   November 27, 2007, 10:52
Default Re: Multiphase Euler-Euler / gas solid
Bart
Difference between solids and liquids? Try diving in an empty swimming pool, you will feel the difference
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
