connecting between CFX11 and Fortran compiler.
Old   November 11, 2007, 05:22
Default connecting between CFX11 and Fortran compiler.
Meir
I have downloaded Fortran95 compiler from Internet. How do I connect between CFX11 and the compiler. How do I set the compiler in my system path??
Old   November 12, 2007, 20:13
Default Re: connecting between CFX11 and Fortran compiler.
hiesus
Hello!
I have the same question. If you write at CFX help release "Fortran, configuring on Windows" it will explain how to set de enviroment for FORTRAN. But I try to do all what it is write with no success... (Note: M.Visual Studio express edition 2005 and M.Platform SDK for Windows server 2003 R2 are for free from Microsoft web).
Does anyone correctly set FORTRAN for ANSYS 11?
Thanks for your help!
Old   November 19, 2007, 06:24
Bloshchitsyn Vladimir
Hello!
You need 1)Install fortran compiller ( recommended Intel Fortran 9.0) 2)Write fortran code by template ( ucf_template.F , it's included in distrib) 3)compile library with cfx5mkext script 4)use this library for own calculations
Old   November 19, 2007, 13:15
hiesus
Thanks for your time and help.
I'm not sure what you mean with: 2)Write fortran code by template ( ucf_template.F , it's included in distrib).
Thanks again.
Old   November 19, 2007, 15:10
vologa
It's mean... you write own procedure and use it by user routines and functions in CFX calculations ( it's defined in CFX GUI)
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Using Curl in CFX11 Cardero CFX 0 July 21, 2009 11:29
how to access each cell of a face? (user fortran) Katariina CFX 3 January 28, 2008 10:16
FORTRAN with ANSYS 11 hiesus CFX 2 December 4, 2007 08:25
USER_GET_MESHDATA in CFX11 Merck CFX 1 August 7, 2007 10:32
