Burning a CH4-H2 Mixture
Old   November 10, 2007, 09:15
Default Burning a CH4-H2 Mixture
Jonathan Lemay
Dear CFD user
I want to run a reacting case burning an homogeneous mix of Methane and Hydrogen (of igual proportion 50:50). Unfortunately it seems this mixture reaction is not present in the librairies. What I tried instead is to established two reacting material (CH4-Air mixture and H2 Air mixture: both beeing reacting mixture). My domain was then multi-component field. I established both component as homogenous. Unfortunatly I am stock with this error:
One constraint equation is needed in the fluid model section for the multi-component fluid. Hydrogen Air mixture.
I cannot run my case and the solver give me an error. Does anybody know how to set-up a Burning Mixture of two different fuel?
Regards
Old   November 12, 2007, 16:10
Default Re: Burning a CH4-H2 Mixture
joey2007
The libraries provided with CFX are for demonstration. For real use the tool CFX-RIF is required. With CFX-RIF you can generate libraries.
Old   November 12, 2007, 18:01
Jonathan Lemay
Thanks joey
Is there anyone who would have this library already done? I do not have access to this software who generate the librairies. From the ANSYS page, it seems pretty easy to generate in my case.
Regards
mixture mass continuity eqn v.s. volumetric mixture continuity eqn kaifu ANSYS 0 June 9, 2011 09:42
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 09:14
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC richpaj OpenFOAM Bugs 2 October 9, 2008 23:14
Variable composition mixture .vs. reacting mixture Ting Wen CFX 0 January 7, 2008 07:04
Simulate a cylindrical combustor burning methane CH4 in air using the finiterate chemistry model zou_mo OpenFOAM Running, Solving & CFD 3 March 30, 2006 00:50
