particle injection at single point
Old   November 9, 2007, 18:23
Default particle injection at single point
drew
I am modeling air at 25 degrees C in a cross-section of a straight capillary. At the inlet I set mass flow rate and at the outlet I set static pressure. I would like to inject a single solid, one-way coupled particle at the point where the flow is fully developed. The location of this particle injection would not be on any regions that I previously defined. Is it possible to do this without using FORTRAN?
Drew
Old   November 11, 2007, 06:38
Default Re: particle injection at single point
The available options to generate particle track origins is clearly discussed in the documentation.
Old   November 19, 2007, 16:01
drew
Okay,
From what I read, to do this I would need to create a user routine which can only be done with fortran. I would also like to add lift forces on the particle. Is this something that must be done in fortran or can I use a cel equation? Thanks.
Drew
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 10:58
How to put melting Point data of inert particle in DPM model subhankar_bhandari Main CFD Forum 0 July 26, 2010 08:28
Particle injection boundary condition fjalil CFX 8 September 23, 2009 10:40
multicomponent particle injection in DPM Ning FLUENT 0 December 23, 2008 09:23
Urgen!How to track the single solid particle inH2O areriko CFX 0 November 12, 2007 04:27
