ANSYS CFX meshing bed of particles
Old   November 8, 2007, 20:31
Default ANSYS CFX meshing bed of particles
Tim Donohue
I have a simulated bed of spherical particles that are drawn in vrml 2.0, which I convert to an iges file through Solidworks. I can then import the iges file into the ANSYS geometry modeller making sure to simplify topology and geometry. I then extrude a cylinder to enclose the particles and use create>body operation>cut material to remove the particles. When I try and mesh this geometry though I get errors. The most common ones are;- *the volume mesher cannot continue. it is contiually adding and removing the same elements *No boundary edge found
I am not very experienced with this software so I am unsure of how to deal with these problems. Any help or advice would be appreciated. Tim.
Old   November 11, 2007, 06:44
Default Re: ANSYS CFX meshing bed of particles
Generally this is caused by the mesher trying to put too large elements in a small gap. Check that you mesh is fine enough to resolve the geometry.
[ICEM] How to set bocos on 2D model for ANSYS CFX (tuts no help) RossFS ANSYS Meshing & Geometry 4 May 22, 2012 09:56
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
Ansys Workbench (CFX) bucket problem njsavage CFX 1 April 30, 2009 10:51
Ansys CFX bucket problem njsavage Main CFD Forum 1 April 30, 2009 10:48
