drag coefficient
Old   November 8, 2007, 02:17
Default drag coefficient
hsn
Hi. I'm a new user of cfx. I have done all the tutorials of the program documentation and of coarse the one with the name of flow around a blunt body(Ahmed body). I was wandering how can I achieve to the amount of drag coefficient by the software? By the way I have searched all the documentation to find a clue on the drag coefficient but I wasn't successful. Thanks for your attention.
Old   November 8, 2007, 05:46
Default Re: drag coefficient
Jim
You can use the "Expressions" tools in either pre or post to extract the force acting on your boundary conditions. You can then use this to calculate the drag coefficient.
Old   November 10, 2007, 01:20
hsn
thanks Jim. I did so and now I know the amount of force acting on the body. But as you know the analyze is symmetric. Should I duplicate the calculated force for whole the body to calc the drag coefficient? hsn.
Old   November 11, 2007, 06:48
Yes. The forces reported in CFX-Post are for the geometry as modelled. Therefore you will need to double some variables due to symmetry.
On a separate matter, I trust you are aware that the solution to the Ahmed body at typical vehicle Reynolds numbers is not symmetric and therefore you cannot use a symmetry plane if you want an accurate answer? In fact getting accurate drag numbers on the Ahmed body is quite a challenge.
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 10:22
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 01:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 13:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
