RPM (+/-) thumb rule
Old   November 6, 2007, 00:36
Default RPM (+/-) thumb rule
studentCFD
hello guys!
While defining angular velocity to any mesh,what is the thumb rule?
Suppose im looking from the negative z and i want the geometry to revolve around z,say in negative y direction(as can be seen in gui),then while defining rpm,it will be positive or negative?
help required.thanks.
Old   November 6, 2007, 06:19
Default Re: RPM (+/-) thumb rule
The thumb rule is if you want the rotation to be in the direction your fingers point then your thumb points in the vector which represents that rotation. In a right hand coordinate system (CFX and most of the world uses a right hand coordinate system) you use your right hand for this.
This is high school level mathematics. I hope this is not new to you - if it is then I fear CFD will be beyond you for a little while yet.
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 17:50
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 04:12
Rule of Thumb to Estimate Total Cells chinc Main CFD Forum 0 April 12, 2011 22:52
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 16:49
is there any thumb rule for mesh size Ram Dayal Main CFD Forum 19 October 17, 2006 15:07
