Adjust the parameter of the geometry
Old   November 5, 2007, 11:09
Default Adjust the parameter of the geometry
Susan
Hi, everyone, in ICEM CFD, first I have made a cylinder, but later I want to adjust the height of the cylinder and add points to the base surfaces. Every time I have to redraw the geometry, and it is time-consuming. Whether is it possible that just adjusting the parameters of the original geometry? If it is, how?
Thanks a lot!
Susan
Old   November 5, 2007, 18:07
Default Re: Adjust the parameter of the geometry
Parametric modelling is best done in Workbench.
Old   November 9, 2007, 08:42
Susan
Thank you for your reply. I havn't installed the workbench. So it seems that the parameters of geometry can't be adjusted in ICEM.
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Force can not converge colopolo CFX 13 October 4, 2011 23:03
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
