Extrude mesh in ICEM CFD
Old   November 5, 2007, 06:17
Default Extrude mesh in ICEM CFD
Susan
My model is that the fluid flows into a cylindrical chamer, then through a round porous medium, and flows out from the other cylindrical champer. The flow and boundary are axisymmetric. First I created two parts, fluid and porous, blocking and meshing in 2D, then extrude them into 3D mesh. I opened it in CFX, use boundary condition as symmetric, then the result is wrong. I think there are some problems with the extrude mesh, but failed to figure it out. Is there anybody can give me help? Thanks a lot!
Old   November 5, 2007, 07:26
Default Re: Extrude mesh in ICEM CFD
Susan
When Extrude Mesh, what do the 'New side part and top part' mean?Just let 'New volume part name, New side part name, new top part name' are inherited, whether is it fine?
Old   November 5, 2007, 18:10
Hi Susan,
If you are new to meshing and CFD can I recommend you use Workbench instead of ICEM? It is much easier to use and for simple meshes you can get good results much quicker.
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 04:46
Loading previously saved mesh in ICEM CFD user0314 ANSYS Meshing & Geometry 1 September 20, 2011 13:46
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 04:54
How to corse mesh in icem cfd? Priety CFX 2 October 2, 2006 04:57
