November 2, 2007, 02:45 |
FSI simulation thermal analysis
I'm simulating a fluid flow in an stainless pipe. I want to ask if I can use two way FSI to compute for the changes in temperature in both the pipe and fluid. I saw a demo about one way FSI where the wall temperature of the fluid was solved first and then loaded it as initial condition of the inside wall of the pipe. However, I want to know the effect of this heat loss to the temperature of the fluid. Do you have any suggestion on how to do it guys? Thanks! Much appreciated, Michelle |
November 3, 2007, 07:56 |
Re: FSI simulation thermal analysis
You can do a CHT problem in CFX - you wouldn't need a two way FSI if all you were trying to solve was heat conduction in the solid domain. If you need the thermal stresses in the solid, or the deformation of the solid is significant, then a two way FSI is necessary.
November 3, 2007, 10:15 |
Thanks a lot johnny!! I will try advise. Thanks again!
FFT for Post Simulation Analysis | faisal_durr | CFX | 12 | March 13, 2012 04:35 |
thermal analysis | raffap | Siemens | 7 | May 23, 2011 03:08 |
wrong values in thermal analysis | Trofrensis | STAR-CCM+ | 0 | December 7, 2009 06:41 |
Transient Thermal Analysis with FSI | Abduri | CFX | 2 | March 27, 2009 03:47 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 14:24 |
