October 30, 2007, 21:00 |
Mixture fraction for combustion problem
Hi everyone
I was wondering if anybody could help me with my problem of getting the mixture fraction available on the result file on my simulation. I am simulating a case in which I am burning Methane and air. I established a material call Methane Air Mixture in which includes CH4, O2 and N2 as pure substance. I simply adjust the mass fraction with the respect of my boundaries conditions for a non premixed burner. Is there an option I have to select to get the mixture fraction as a variable available in the results file. I tried reactive and non reactive flow but I am only getting the mass fraction of my species and not the overall mass fraction? Could somebody give me a tip? Best Regard |
November 1, 2007, 16:22 |
Re: Mixture fraction for combustion problem
Hi, there is more than one way. You can just rerun your case with Burning velocity model. With this approach mixture fraction is a primitive variable. Solver setups it automatically.
Alternatively: you can calculate using CEL in CFX post. |
November 4, 2007, 20:55 |
Hi Joey
Thanks for your tips I will try this way. What do you mean with the Burning velocity model? Is it a combustion model available in CFX-Pre? Is it a turbulente model? Finally I found out a way to get what I was looking for. I was running a non-reacting case in which I wanted to estimate the mixing field of CH4 surrounding by air. It work out for the mixture fraction choosing a right combustion model (containing good librairies of flamelet) and setting it to ISOTHERMAL (I chose 300K) in the field of heat transfer. It finally work this way. Regards |
November 5, 2007, 15:57 |
You are right. I am sorry that I missed. You have to use one the combustion models based on the mixture fraction approach. In the case of a diffusion flame this is Laminar Flamelet model. In the (partially) premixed cases this is the Burning velocity model. You can chose both models when you set up a corresponding reaction. (In the library they are termed fll)
Volume fraction of dispersed phase to determine DPM, VOF, Mixture model | Mohsin | FLUENT | 5 | March 5, 2018 08:47 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
mass fraction of mixture | wlt_1985 | FLUENT | 2 | July 28, 2011 10:39 |
Mixture fraction with PPDF combustion | erikrijk | STAR-CD | 0 | March 18, 2009 09:49 |
Problem on compacking volume fraction | youngan | CFX | 0 | August 16, 2003 03:41 |
