I'm trying to edit in DesignModeler a turbine created in BladeGen, but there is a message error: "ImportBGD doesn't support the Trim Meridional Profile.".
Does anybody know how to fix it? Thanks! |
hi sandman!
in the output section of bladegen click on use design profile,then save and import in bladegen.it will work. |
Thanks, Pankaj!
It worked! |
How to create wind turbine blade in DesignModeler | Atit | CFX | 5 | December 26, 2012 06:13 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
Rotating blade in circular/square vessel (Salome+OpenFoam) | voingiappone | OpenFOAM | 0 | May 19, 2011 11:38 |
stress analysis of a rotating beam(wind blade) | Cheyannne | ANSYS | 0 | October 19, 2009 17:06 |
Meshing a 3D, tapered and twisted blade with Gambit-TGrid | teskio | ANSYS Meshing & Geometry | 0 | July 3, 2009 10:36 |
