Time Transformation with transient rotor stator interface |
January 22, 2023, 12:31 |
Rep Power: 3 |
Good evening,
while trying to set up a time transformation with a transient rotor stator interface, I can't find the option "Time transformation" in Transient Blade Row Models, instead I only have "profile Transformation" and "Fourier Transformation". Have anyone had the same problem? Thanks |
January 23, 2023, 10:07 |
Rep Power: 33 |
Is your problem using a compressible or incompressible material? or does your model include mesh deformation?
January 23, 2023, 13:04 |
Rep Power: 3 |
January 23, 2023, 15:57 |
Rep Power: 33 |
Time transformation cannot be used with deforming meshes. It is a limitation of the model.
You need to use Fourier transformation then.
January 23, 2023, 16:22 |
#5 | |
Rep Power: 3 |
I already tried with Fourier Transformation, but I am obtaining a solution that fluctuate so much (I am talking about Aerodynamic damping), so I was searching for an alternative. I also read the CFX-pre Solver Modelling Guide and I think I followed all the important steps for setting up a FT. |
#cfx, #timetransformation, #transient |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 10:10 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 03:05 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
