Rep Power: 4 ![]() |
I am using CFX-Pre to set up a simulation and want to rotate a mesh via the "transform mesh" command under "Mesh". Unfortunately when I click on it no window is opening. I've checked if the window is hidden or popping up somewhere else but no. Same problem happens with right-clicking on any interface and trying to "edit in command editor". Same phenomenon. It seems as if something is preventing Ansys to open a pop-up window. I have opened the workbench on a different pc on which everything works perfectly. The ansys version is the same on both PCs. I would be glad if anyone can help. Thank you! Felsch |
Rep Power: 33 ![]() |
Are you using a multiple-display computer?
An alternative is to hard reset the preferences for Ansys CFX. Close all your Ansys CFX applications before attempting this. Open a File Explorer window, go to your C:\Users\<your account>\.cfx and either remove CFXPreferences, or rename it to say CFXPreferences_old and see if the problem goes away.
CFX Pre & Post Startup Error | vigges | CFX | 12 | March 17, 2023 03:30 |
CFX Pre not importing Mesh | ajhunte | CFX | 10 | October 31, 2022 16:52 |
Accessing cell values (CFX Pre and CFX Post) | brahmarishiraj | CFX | 14 | June 24, 2014 19:12 |
Extracting a Geometry from CFX Pre | eh14410 | ANSYS | 0 | June 10, 2014 10:17 |
CFX on Windows HPC: Confused about cfx_ccsoptions.txt | FrankS | CFX | 3 | October 31, 2013 18:31 |
