December 11, 2022, 15:34 |
Mass flow inlet boundary condition
I am simulating a steady state case using k-epsilon and the material used is Air ideal gas. I am trying to fix the mass flow at the domain inlet however when I check the results the velocity is lower than expected and the density higher, since I am missing one variable which I cannot input into CFX-pre. The mass flow is a bit higher than expected. Using mass conservation and ideal gas law if I provide mass flow, temperature and density everything is fixed while now I only have the first two. Could it also be a convergence problem? The RMS for mass is in the order of e-7 while momentum e-5 using a fine mesh. Thanks in advance for any suggestions! |
December 11, 2022, 16:26 |
Rep Power: 144 |
Please attach your output file and an image of what you are modelling.
December 12, 2022, 10:28 |
Rep Power: 33 |
How are you checking the mass flow at the inlet?
massFlow()@Inlet ? or areaInt (density * Velocity dot Normal)@Inlet Though theoretically the same, numerically they are different. The massFlow()@Inlet must be EXACT what you provided.
Inlet Boundary Condition for Open Channel type flow | Akshay_11235 | OpenFOAM Running, Solving & CFD | 12 | April 15, 2024 04:05 |
Wind tunnel flow simulation boundary condition issue | charan3007 | SU2 | 0 | October 21, 2021 08:27 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Constant mass flow rate boundary condition | sahm | OpenFOAM | 0 | June 20, 2018 22:45 |
Mass flow rate boundary condition with negative values | ashtonJ | CFX | 3 | November 26, 2014 05:21 |
