how to mesh the small inlet?
Old   October 12, 2007, 02:40
Default how to mesh the small inlet?
xiao
I want to simulate some big vessel aerated by a gas ring sparger. the sparger is a pipe with many small holes which is bended to a ring)
the gas inlet (samll holes) is very small, how can i mesh them?
Old   October 12, 2007, 08:29
Default Re: how to mesh the small inlet?
Chirag
If you are using ICEM, best solution will be to create seperate bodies, for the region where you want fine mesh (around inlet) & rest of your domain. Define different mesh sizes for these bodies & surfaces attached to them. But, before this have a careful look at your geometry & see if you can simplify it. I mean, have common inlet instead of many small holes. This may not be always possible. So, just have a look.
Best luck, Chirag
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
