Mesh Deformation Problem
Old   October 9, 2007, 01:37
Default Mesh Deformation Problem
Virag Mishra
Hi I have tried to work on the work out a few problems of mesh deformation ,including Tutorial 20:Fluid Structure Interaction and Mesh Deformation using Using a Junction Box Routine to Govern Mesh Deformation. The problem is set well in pre but whan its exported to Solver it ends with an error massage Reading mesh for map generation File NOT read: *\meshes\Fluid.0 where Fluid.0 is the name of the mesh coordinte file at the start of timestep and writing a crash recovery file
ERROR #001100279 has occurred in subroutine ErrAction. | Message: | Stopped in routine SET_MESH_USER
Even in the Tutorial example the program is unable to read the initial mesh file, so I guess their is no problem with the mesh topology or the coordinate.
Anyone with any Idea
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 20:39
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
