October 8, 2007, 09:30 |
error during creation of ".gtm" file
hai,
I am working on cfx 11. Presently i have meshed my model. But at the end when ".gtm"file is being created i'm getting error as "THERE WAS PROBLEM CONVERTING THE MESHER OUTPUT INTO THE GTM DATABASE". I have enoughf memory for the files(for temperory as well as actual meshed files (about 23GB)) and all the ".lck" files have been removed. But still i am getting the error. Can you please suggest me a probable reason for this and a solution? |
October 9, 2007, 02:38 |
Re: error during creation of ".gtm" file *NM*
October 9, 2007, 08:08 |
HI, check it, is it really volume mesh or surface mesh? if it is suface mesh only then it cant save as a name of .gtm ok.
October 10, 2007, 08:55 |
which mesh tool you r using? what type of geometry it is?
October 23, 2007, 02:57 |
hai pankaj i have meshed my model using Ansys cfx meshing.My model is complex and have 36lakh elements.
thanks. |
October 25, 2007, 06:20 |
mesh tool: cfx mesh file .agdb (design modulor)
tecio compilation errors in latest 1.6.x | rsamuel | OpenFOAM Bugs | 2 | June 25, 2021 08:10 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 17:33 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
