exporting node coordintes from icem
Old   October 6, 2007, 10:06
Default exporting node coordintes from icem
Virag Mishra
hi all
I have generated a mesh in ICEM, now I want to export the node coordinate infornation of each node to a file. How is that done ?
Old   October 8, 2007, 09:19
Default Re: exporting node coordintes from icem
Elian81
The only way i know is that: open the gtm file using the post of cfx, and go to file export. From here you can create a file .csv with the coordinate of the points
Old   October 8, 2007, 09:20
Elian81
The only way i know is that: open the gtm file using the post of cfx, and go to file export. From here you can create a file .csv with the coordinate of the points.
Old   October 8, 2007, 10:20
Anantha
Hallo, One way which directly comes to my mind now is to write the mesh output in Star-CD format. It writes the cel data, vertex data,... You have the answer for your question in .vrt file written. It is the vertex data and contains all the nodal information. Here you don't need any solvers.
Regards Anantha
Old   October 8, 2007, 12:45
Virag Mishra
Hey thanks, Its saving a step one step from what I did ICEM->CFX PRE->CFX SOLVER->CFX POST.
[ICEM] Node Number vs. Node_ID & ICEM vs. CFX Araz ANSYS Meshing & Geometry 1 April 25, 2011 12:03
problem exporting from icem to fluent jc_muaddib FLUENT 1 June 16, 2010 05:16
[ICEM] Exporting Grid Volumes/Areas from ICEM to Calculate Discretization Error Josh ANSYS Meshing & Geometry 4 May 20, 2010 14:40
Problem exporting big meshes from ICEM to Fire Emil CFX 0 October 10, 2008 14:06
Exporting Meshes from ICEM to Fluent zi FLUENT 4 August 9, 2005 11:58
