Aspen
Rep Power: 3 ![]() |
Hi all,
I have a simulation with an object rotating about a point. I am trying to set up a coordinate frame that rotates with the object. I made a new coordinate frame and set the frame motion to 'Rotating'. However, when I try to run the simulation I get this error and the simulation stops: ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine GET_CBCK_VALUE Does anyone know what this means/how to resolve it? I know it has to do with the rotating coordinate frame because if I set the frame motion to stationary then I stop getting the error. |
Daniel
Rep Power: 9 ![]() |
Do I understand correct, that you have a fixed point and an object, that is rotating around this point ? And then you created a new coordinate frame that is rotating?
Did you specify the correct coordinate frame for your object in the rotating frame ? If the object rotates around the point P, then you should specify a coordinate frame where the rotating axis goes through P. Have a look if you maybe used the global axis instead of your new axis. |
#3 | |
Gert-Jan
Rep Power: 27 ![]() |
What are you tring to do? Do you have 2 rotations at the same time? Something like a spinning object that rotates around a central point? |
#4 | |
Rep Power: 33 ![]() |
I think you may also have some expression using the rotating coordinate frame? Say something along Function(Variable)_x_MyRotatingFrame@Location
#5 | |
Aspen
Yes, that is correct. I have an object in a domain rotating around a point, and created the rotating coordinate frame at the center of rotation. The center of rotation and the rotating coordinate frame are both at the global origin. |
Aspen
I have a rotating domain which contains the object, and this is rotating around the global z axis. I am trying to make a rotating coordinate frame at the origin so that I can monitor the forces on the object with respect to the rotating frame.
Aspen
Remove the expression, and check how far the setup proceeds.
#9 |
Aspen
#10 |
As far as I understand, they are not supported as part of the CEL-integrated functions.
#11 |
Aspen
#12 |
Gert-Jan
In CFD post you can create a coordinate frame which can be used in expressions to calculate forces, moments, etc. You can use the syntax as examples for expressions in Pre. Not sure if Pre or the solver manager will eat it, as Opaque explains, but then at least you cannot blame the syntax.
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
