October 3, 2007, 07:08 |
Zero gradient Temperature Bc
Hi all, I need to specify zero static avarage pressure,and zero temprature gradient at the outlet. How can I do this in cfx 11?
Thanks in advance, Selim |
October 3, 2007, 19:32 |
Re: Zero gradient Temperature Bc
You cannot specify temperature (or temperature gradient) at an outlet. The temperature at the outlet is defined by the flow upstream only. What are you trying to do? Glenn Horrocks |
October 4, 2007, 02:56 |
Can't you specify temperature gradient at the outlet by using the "outlet" boundary condition? Isn't the "outlet" boundary conditions second derivatives equal to 0? So you are indirectly specifying a temperature gradient by choosing the outlet condition.
October 4, 2007, 19:20 |
From the CFX V11SP1 theory manual, outlet boundary conditions: "For scalar quantities, the ANSYS CFX-Solver imposes a constant gradient constraint (generally non-zero) at the outlet boundary." It does not define what gradient it does actually impose or how it is calculated. Does anyone know this? Regards, Glenn Horrocks |
Temperature gradient in CFX | Chander | CFX | 5 | January 7, 2015 04:00 |
specified shear at wall - temperature gradient - UDF - access violation error | senD | Fluent UDF and Scheme Programming | 9 | September 18, 2014 08:29 |
Wall correction for the temperature gradient | Hagen | OpenFOAM | 0 | March 7, 2011 21:04 |
Temperature Gradient at Wall | sven | OpenFOAM | 7 | November 1, 2010 18:25 |
temperature normal gradient on a boundary | Sandrine | Main CFD Forum | 2 | June 10, 2009 17:34 |
