Could not invert control surface Ap
Old   November 16, 2022, 19:03
Default Could not invert control surface Ap
QC
Mohsen_mtl is on a distinguished road
Dear All,
I am working with Ansys CFX for more than 10 years. During this period, I had no major problem with it. But now, I have a project for the simulation of the flow field in an engine.
I must say I realy stuked! I am desperate on understanding and solving this problem! I can not find any solution to it. Is there anyone to give me a hint?
Parallel run: Received message from slave
Slave partition : 22
Slave routine : ASS_GLOBCS_IAP
Master location : Message Handler
Message label : 002100088
Message follows below - :
| ERROR #002100088 has occurred in subroutine ASS_GLOBCS_IAP. |
| Message: |
| Could not invert control surface Ap at the following location: |
| Domain Interface : R1 to R1 Internal |
| Location (X,Y,Z) : ( 0.22981E-01,-0.35690E-01, 0.83732E-01) |
| ERROR #001100279 has occurred in subroutine MESG_RETRIEVE. |
| Message: |
| Stopping the run due to error(s) reported above
Mohsen_mtl is offline   Reply With Quote
Old   November 16, 2022, 22:11
Opaque will become famous soon enough
From the message, it seems the equations for the domain interface at the tip gap of your rotor are decoupled.
How did you create the mesh? Using TurboGrid? If you did, check if you can recreate the mesh with a conformal tip gap. It is possible in recent releases of TurboGrid.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   November 23, 2022, 13:50
QC
Dear Opaque
I generated the mesh with Ansys Turbogrid. Before posting my problem here, I tried to change the mesh in the tip clearance region, but I had no progress. Now I am generating the mesh with new parameters. I hope it works! Thanks
cfx 19.2
Error in gmshToFoam on ESI v2106 siefer92 OpenFOAM Programming & Development 4 July 17, 2021 06:11
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 13:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
Invert control surface Ap?? sercro CFX 0 March 16, 2011 13:53
