effect of difference in temperature on velocity
Old   September 29, 2007, 11:10
Default effect of difference in temperature on velocity
sravani
Hi all, My study is effect of flow and heat across a confined square cylinder in steady state regime.the fluid i am considering is water. my question is whether the variation in difference of temperature between inlet temp and square cylinder temperature effect the velocity.
thanq...
Old   October 1, 2007, 19:29
Default Re: effect of difference in temperature on velocit
I bet you'll find the flow is not steady state. The temperature difference will only be significant if it generates significant buoyancy effects compared to the existing flow.
Old   October 2, 2007, 02:41
sravani
hi, thanq..
Results of CFX Simulations Sof_70_Usthb CFX 3 July 9, 2011 07:15
Difference between "Total Temperature and static temperature" rohangulavani FLUENT 0 July 7, 2010 12:37
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 19:29
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
