November 6, 2022, 03:31 |
Compressible Flow, Temperature Problem
Tim
Rep Power: 5 |
Hi everyone,
I am simulating a gas turbine stator passage and I have some Problems with the convergence. I set a Monitor Points behind my Blade near to the Shroud for Pressure and Temperature. While the Monitor Point for Pressure is not changing, the Monitor Points for Temperatur is Oscillating. The RMS Residuals are between 10^-4 and 10^-5. The flow is compressible, so that I am using the Total Energy Modell with Air Ideal Gas. At the Inlet I set a Total Pressure and at the Outlet a Static Pressure. Does anyone habe any suggestions? Tim |
November 6, 2022, 06:43 |
Rep Power: 144 |
My suggestion is read the FAQ on this: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
November 9, 2022, 12:55 |
Rep Power: 33 |
Would you mind posting plots for the convergence of MassMomentun and Heat Transfer?
You can also create an additional plot for the Imbalances showing for P-Mass, H-Energy and U/V/W-Mom
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 03:10 |
Steam Turbine Compressible flow convergence problem... | bharath | FLUENT | 0 | November 8, 2013 05:41 |
Newbie to compressible, viscous flow. Advice on approach to problem? | bzz77 | Main CFD Forum | 4 | December 4, 2012 08:59 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 08:51 |
Need help with a compressible flow problem | JP | FLUENT | 0 | August 19, 2008 14:11 |
