Lee evaporation model in Ansys CFX with CEL expressions
Old   October 25, 2022, 11:56
Default Lee evaporation model in Ansys CFX with CEL expressions
Steffen
SteffenBcfd is on a distinguished road
I'm trying to model evapoartion of water in Ansys cfx with the Lee model.
The CEL expressions are not difficult to implement, but I guess I made something wrong with the source definitions in the subdomains.
The setup is very simple (pic below), a fluid domaine is filled with saturated water and has a heated wall at the bottom.
Fluid1 is saturated water and Fluid2 is saturated water in gas state. Initialy the domain is filled with liquid water.
The walltemperature is 10 K above the saturation temperature.
I used the following expressions:
The sources (mass and energy) are bound in this way:
The mass transfer is not working. I don't have a clue what's wrong.
Maybe someone has an idea
Greetings
Steffen
SteffenBcfd is offline   Reply With Quote
Old   October 25, 2022, 18:55
Why don't you use the built in boiling model? There are a few models built into CFX, in this case I suspect the non-equilibrium boiling model may be suitable.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 26, 2022, 03:53
Steffen
Because additionally, I intend to use the build in cavitation model. Unfortunately, cfx allows only one mass transfer at a time in the GUI
Old   October 26, 2022, 06:46
You are trying to model cavitation and boiling? Good luck with that one, I trust you are a CFD expert. This is not something to be attempted by beginners.
Your source term is a function of volume fraction but you have not defined a source term volume fraction coefficient. You are probably going to need to set the source term coefficient to get it to converge. But your source term is a horrible step function which is going to be very difficult to converge at the best of times - it may well never converge.
cel expression, cfx, evap-condense model
Evaporation model in ansys Fluent 12.1 oldisbest Fluent UDF and Scheme Programming 12 March 26, 2020 10:11
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? rsin CFX 19 December 29, 2018 05:43
How to Tackle Evaporation Condensation model of ANSYS Fluent ?? :( nands_bullwalker Fluent Multiphase 4 June 4, 2017 02:01
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
Importing 3D data as CEL into ANSYS CFX 11.0 Dave W. CFX 9 October 19, 2007 09:18
