Centrifugal pump trailing edge wake region influence |
Daniel
Rep Power: 9 ![]() |
I have a question regarding the wake region produced by the trailing edge of a centrifugal pump impeller. My setup is as follows: Inlet pipe, suction chamber, impeller, volute, outlet pipe. I usually have the impeller domain, which ends at the trailing edge and directly enters, via a transient-rotor-stator interface, into the volute. This is mostly close to the experimental and real setup. Now, I did see results of simulations including an outlet domain to include the wake region of the impeller. Therefore, the interface between impeller and volute is shifted to a higher diamter of the volute. Can somebody maybe explain to me which influence including the wake region could have on the numerical result ? In which way could it influence hydraulic data such as the head ? Sadly, I am working on other simulations which hinder me in doing a comparison between both cases. But I am really curious if someone has experience with this. Thank you! Daniel |
#2 | |
MANU P ANAND
Rep Power: 12 ![]() |
I think there will be difference, since there is change in domain, as you said you had included outlet domain, Can you specify the interface method. But if your mesh is good you van capture wake effects. |
Daniel
Thank you for your reply.
Yes, I am sure, that there will be a difference. But, I thought about an fluid mechanics answer - maybe increased momentum transfer or so... I will get back when I finished the simulations. The interface is Transient-Rotor-Stator. |
[ICEM] Meshing Wing with low Y+ value and sharp trailing edge | sonic109 | ANSYS Meshing & Geometry | 0 | July 27, 2015 09:29 |
[DesignModeler] 3mm Trailing edge radius on closed airfoil | henrikdahlberg | ANSYS Meshing & Geometry | 1 | June 10, 2015 05:04 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
The trailing edge velocity | maximus | Main CFD Forum | 0 | March 6, 2005 00:27 |
trailing edge problem | Kuo Wei-Jen | Main CFD Forum | 2 | April 14, 1999 10:09 |
