User Defined Variable in CFX PRE
Old   September 21, 2007, 13:11
Default User Defined Variable in CFX PRE
Hamidur Rahman
Hi Dear All, Could anyone please tell me how can I define variable (say nusselt number)in CFX PRE to get the result?
Old   September 21, 2007, 14:43
Default Re: User Defined Variable in CFX PRE
CycLone
Can you explain the context of the calculation? Are you doinga multiphase analysis?
Old   September 21, 2007, 15:18
Hamidur Rahman
Hi Cyclone, it is a gas turbine simultion with one stator and two rotor. I know the standard equation for Nusselt number applicable for my case. I am not sure how the command should be given in CFX PRE. Thanks for your reply
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 17:50
(DPM) Names for User Scalars (instead of Use Variable 0)? sega Fluent UDF and Scheme Programming 3 April 20, 2010 08:33
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 06:29
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 10:19
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
